Results 1 to 8 of 8
Thread: Spider cracks along rub rail
  1. #1
    Join Date
    Sep 2006
    Location
    Illinois
    Posts
    607
    Default Spider cracks along rub rail
    Recently I wastold that if you took a router and ground a line above the screws on the rubrail that this will help reduce the spider cracks along the rub rail. But keep the line under the rub rail..
    Going thru the gel and into the glass!
    I understand that Cobalt does this on all their hulls.
    Has anyone tried this yet?
    AOTH IX/X ZX Peoples Choice award
    2000 28ZX Scorpion.. SOLD
    1986 Z29
    1973 X 18 #61 Project BBC
    1979 Criterion
  2. #2
    Join Date
    Oct 2009
    Location
    NEW HARTFORD, CT
    Posts
    207
    Default
    Kinda like drilling a hole at the end of a crack in sheet metal.
    I can see that making sense. If a crack should start at the screw, the crack runs out of material to continue on.
    Ken
  3. #3
    Join Date
    Nov 2006
    Location
    Left side, deep South, Canada
    Posts
    1,908
    Default
    I have no idea Mike but that sounds like a GREAT idea .
  4. #4
    Join Date
    Oct 2007
    Location
    New Hampshire
    Posts
    647
    Cool
    Id just counter sink the gel away from the screw head with a dulled drill bit, 1- 2 sizes bigger than the screw on an assembled boat. Flexible caulk will fill in the voided gel so it can have a little give when flexed. Its the high degree of brocol hardness + poor flexable modulas of the gel around the screw that starts the cracking. I assume they use a jig on top of a cleaned up hull part, using a high speed router. Id use a Fein saw if I was trying to cut a straight line on something assembled.
  5. #5
    Join Date
    Jul 2009
    Location
    Huntingdon Valley PA
    Posts
    777
    Default
    I would think that IF you want to do this ~~~all you would really need to do is make a very fine saw kerf cut , or small router bit slice, just through the gellcoat to the very top of the fiberglass layer,
    No real need to actually cut into the under layer of glass itself.
    I actually like the idea of grinding a small 1/4"-5/16 "circle, or countersink hole, around each drilled rubrail screw hole in the gell itself much better.
    As we all know gell is very brittle , and stress cracks very easily.
    I once had a 1970 23' foot Chris~Craft Lancer inboard boat with unusually thick 1/4"+ white gell & center blue gell race stripe on it's deck.
    This very thick gellcoat stress cracked all over the place for no apparent reason other than it being just too thick to flex with the hull .
    The thicker the gell~~~the more it will be prone to stress crack .
    I finally rough sanded the entire deck removing much of this gellcoat thickness ,with a small Skill sand-cat belt sander & filled the remaining deeper gell cracks with old Dupont Coralar epoxy primer surfacer; and top spray coated it with white Imron, and blue imron center stripe and quickly sold the boat~~~telling the new owner, a neighbor & friend, about this deck gell cracking issue & repair. He was happy with the "repaired" boat; & the deal.
    I knew this was Not a proper gell stress crack repair method.
    BUT~~~ I still lost my shirt on that Lancer sale !
    I also sprayed that Imrom with a Binks #7 gun with only a twin carbon filter painter's mask.
    I guess I took five years off my life on that imron spray job alone ?
    The boat is still in the water today still owner by my neighbor with this very same Imron job I did years ago~~ with few signs of any deck cracks some 20+ years later.
    That Lancer is now considered a "Classic" and the older owner loves this boat and would Never part with her.
    BRAD HUNTER
    Huntingdon Valley Pa (Just outside Philly)
    215 947 4676 Home
    silverghost1926@msn.com
    Donzi 18 "Benchseat 18 Project "Owner
    Chevy 454 SS Tow/Sport Pick-Up
  6. #6
    Join Date
    Jul 2011
    Location
    West Mich
    Posts
    78
    Default
    Well ....first off........ if you router thru the jell into the glass you actually are taking away the structural intergrity of the layup .....which in reality means you have done nothing to properly repair those cracks listed above which will come back in the long run , and like anything else on a fiberglass boat you will need to properly prep the surface ( grind ) adding a little beef to the area's of concern .....................just my 2 cents which is three cents short of a nickle...........................
  7. #7
    Join Date
    Sep 2006
    Location
    Illinois
    Posts
    607
    Default
    Quote Originally Posted by OFFSHORE GINGER View Post
    Let me toss another penny. this is pre crack.....
    1986 Z29
    1979 Criterion
  8. #8
    Join Date
    Nov 2006
    Location
    Posts
    1,908
    Default
    The gell gives you nothing in the lay-up. Going through a layer of glass does tho, I will give you that.
Similar Threads
  1. 16-18' deck hand rail
    By BUIZILLA in forum Parts For Sale
    Last Post: 12-28-2011, 06:48 PM
  2. Gel cracks
    By woobs in forum "Classic" Donzi Technical Discussion
    Last Post: 11-02-2011, 02:32 PM
  3. Grab Rail Diameter
    By 86fxst in forum "Classic" Donzis Discussion
    Last Post: 07-29-2011, 05:26 PM
  4. Alum 1" J Rail for sale
    By MIKEO in forum Parts For Sale
    Last Post: 01-31-2010, 11:42 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
