No worries tripper...... Cracked the lower from the upper.....
Did not break the vertical shaft BUT it seems the lower gears are shot and the shaft will not turn.....
Best case..... go throughout the lower completely and inspect the upper for debris and hope it is OK but will it be thoroughly inspected before deemed healthy.
Worst case.... Trashed the whole thing upper and lower and zinging the motor when it blew bent some valves and chit......
Either way I will be there sporting fresh gear ready to run!
Now back to the hunt for a blackhawk !!!!![]()
